It is currently Mon Aug 04, 2025 4:03 am
PostPosted: Sat Feb 07, 2009 1:11 pm
First name: Danny
Last Name: Vincent
I'm soon to be finishing a maple and sitka parlour. Yay! I read an article in FWW a while back on finishing maple first with water soluble aniline dye and then coat with amber shellac to achieve a bit of an aged look. I picked up a packet of amber dye from Lee Valley but have yet to play with it. The process is, dampen the wood, re sand and apply dye. I'm hoping someone might be able to share some knowledge on the something of this nature? I'll be top coating with nitro.
Also, if you do top coat with a tint, amber shellac or tinted nitro, what do you do if you burn through the finish to bare wood when you're buffing?
And while I'm on the subject of finishing, I use Becker Acroma lacquer on cabinets. This is the nicest product I've used yet. I use 25 degree sheen and it has an incredibly silky smooth feel to it. I've played Tru Oil necks and I think this would have an even nicer feel. Any reason why I wouldn't use it on a neck?
And the last time I was at the plant buying lacquer I let the tech guy sell me a gallon of Becker Acroma post cat high gloss. Apparently someone he knew uses it for musical instruments. Further questioning and it turned out buddy in the back re finished a guitar with it. :lol: Has anyone had any experience with this product?
I know, I'm just full for questions this morning but man, you can sure make a science out of finishing. And some of the end results like we see here make it worth the time and effort.
Thanks For Your Help,
Danny
PostPosted: Sat Feb 07, 2009 7:39 pm
See my answers below.
Happy Finishing!
If you are using the water soluble type dye then raising the grain before dyeing is not a bad idea. The dye is used to pop the grain too not just give it a vintage look. What I do is use a darker colored dye on highly figured maple and then sand back to bare wood. The dark dye sits in the highly figured grain. Then I go over the top of this with a shellac dyed the color I want. In your case this would be an amber color. I use a one pound cut of blonde and add the dye. The shellac serves as a binding agent for the dye. You can spray or rub this on the instrument. I then topcoat with lacquer or urethane.
Also, if you do top coat with a tint, amber shellac or tinted nitro, what do you do if you burn through the finish to bare wood when you're buffing? YOU DON'T! I put several clear coats over my color coats and you make sure you don't sand through into the color coats!!!
And while I'm on the subject of finishing, I use Becker Acroma lacquer on cabinets. This is the nicest product I've used yet. I use 25 degree sheen and it has an incredibly silky smooth feel to it. I've played Tru Oil necks and I think this would have an even nicer feel. Any reason why I wouldn't use it on a neck? I don't see why not.
And the last time I was at the plant buying lacquer I let the tech guy sell me a gallon of Becker Acroma post cat high gloss. Apparently someone he knew uses it for musical instruments. Further questioning and it turned out buddy in the back re finished a guitar with it. :lol: Has anyone had any experience with this product? I have never used this product. This doesn't mean it won't work. Do some sample boards and see if it works for you.
Danny
PostPosted: Sun Feb 08, 2009 10:32 am
First name: Danny
Last Name: Vincent
That's great Robbie. Thanks a bunch. I started playing around with some product yesterday. The dye looked just OK on maple but not so hot on spruce. I'll give it a try like you suggest and sand back after it dries. I picked up a litre of Amber lacquer tint. I likes some of the results with that.
Danny
PostPosted: Sun Feb 08, 2009 3:50 pm
Did you put finish over the dye? You won't get any idea what it will actually look like unless your sample pieces have finish on them.
Rob
PostPosted: Sun Feb 08, 2009 7:24 pm
First name: Danny
Last Name: Vincent
Rob, I didn't put finish over the dye. I did some more samples today and they still come out looking like baby poo, not the wonderful sounding honey amber, as it's called. I'll shoot a little finish over the samples. I guess the worse I'll get is shiny baby poo.
PostPosted: Mon Feb 09, 2009 10:42 am
It's hard to apply dye directly to spruce without it getting blotchy. I prefer to shoot tinted finish which comes out a lot more even.
Users browsing this forum: No registered users and 60 guests
